The Group B Grocery Getter
Edit from the original first post: This car is being built as a fully prepared hillclimb car. The good posts start at around page 3. Progress is slow, but I will always update this thread.
Specs for the car are as follows:
Engine:
-Audi AAN block bored to 82mm
-Audi WN/WH 77.4mm stroke crank as opposed to the standard 86.4mm crank. Balanced
-Pauter custom rods to accommodate the very short stroke crank.. Rod to stroke ratio will be somewhere around 1.91
-Wiseco custom piston from Geoff Gerner of Four Ring Performance
-Custom dry sump oil pan
-Peterson 3 stage pump
-Geoff Gerner's exclusive ATI Super Damper
-Ported and polished head with .5mm oversized intake and exhaust valves
-Borgwarner EFR 7163 (for now)
-Custom exhaust manifold
-Custom intake manifold
-Motec M130 ECU
-Intercooler will likely come from Treadstone
-Rear mounted radiator
Drivetrain:
-6 Speed 01E
-Advance Automotion dogbox gear kit
-TTV billet Flywheel
-Tilton twin disc clutch
-High bias torsen center diff
-Shortened prop shaft to accommodate the engine being pushed back about 2"
Those are the main things besides a legal roll cage which I will fabricate myself and the other bits that involve tuning the chassis which I will sort out as I go.
IMG_20150906_112355_564 by dougkehl1, on Flickr
IMG_20150906_112522_713 by dougkehl1, on Flickr
Engine:
-Motec M130 ECU
Drivetrain:
-6 Speed 01E
