Re: Project update (vwrabbit)
looks like mine did a few weeks ago.... those rust hole look small until you start poking around.
I welded patch pieces in my floor and primed and sealed them. After that, I got a two part bedliner spray and a shultz gun and did the rocker panels and the floor... Should hold up real good now..
Do some POR 15 on the joints and go over it with this:
Designed to seal sheet metal overlap joints that have been spotwelded, riveted, or bolted together. Can be painted when dry. Remains flexible and resistes oil, fuel and other automotive fluids.
I used this in all the areas that had cancer on my caddy. The best way to put it on is with some THICK rubber gloves.. I used latex and it ate through them in about 5 minutes
. I smeard the stuff all over the entire floor befor putting down the bedliner spray...
http://products.mmm.com/us/auto_mar...PLPKL4XgeGST1T4S9TCgv6DTWTJQPBBglGSGNBQMNGZbl
above is a link to more info about it.
A lot of guys on vortex swear by POR 15
P.S. The dealer can still get the battery tray. I put a new one in my old rabbit... Kind of a pain in the ass to weld, but it sure looks nice with a new one.
