Re: pros and cons of chipping (bac)
quote:[HR][/HR]If you buy an APR chip with EMCS, ECU swapping will be a thing of the past.
How much is your time worth?
http://www.goapr.com
[Modified by Electron Man, 9:48 AM 11-30-2001]
Can you explain further?? ThanX!![HR][/HR]
I will since I have it, you hold down the cruise control button for 5 seconds, you check engine light will begin to fash once a second for 5 seconds, this means that you are in program #1 as of the moment, program #1 is stock mode so allyou do is let go of the cruise control and program #1 is activated and stock boost levels are retained therefore keeping you passat from scaring the crap out of the VW techs and allowing you to keep your warranty
. Now, your car is done being serviced, and you fell like hauling some ass, hold down the cruise control button once again, the light will once again begin to flash once a second for 5seconds, however, this time keep it held, you check engine light then begins to flash twice a second, for 5 seconds, just release your cruise control while you check engine light is still flashing twice, and then hold on, because its chip time baby! I have been serviced 2 times with the APR, so far so good, nothing short of taking your ecu out and opening it up can give you away, and no one will do that unless you REALLY piss them off by like sleeping with their sister or something
. Anyways, check my sig for 1/4 mile times with an APR and a decent 60', I might be going to the track tonight to run my car, but I will most likely be running my friends A4 with APR race program and race gase, I hope to put it into mid 14's
