1 - 7 of 7 Posts
What is the benefit of running a low temp thermoswitch/stat does it actually keep your engine running at cooler temps when under stress is there any benefit on a daily occasional track car?
Re: pros and cons of lower coolant thermoswitch/stat (Mr. Knappy)
would you recommend it for an 8valve daily that wont see much more than a cam exaust small (5psi) junk yard turbo setup and maybe next summer an aba block or is that too cold?
I don't post here often, but I will say that I installed both the cooler switch and thermostat. My car runs much cooler, runs better too. The needle rarely gets past the LED bulb.
1 - 7 of 7 Posts
