1 - 6 of 6 Posts
I've got a bunch of pulleys sitting around for my 8V GTI engine. Some are from an 8V with A/C and some without. Unfortunately no combination of what I have lines up right. Can someone point me at the part numbers for a complete set of NON-A/C pulleys. I think I'll also need a different alternator because I have an A/C alternator.
If anyone has these parts for sale, I'm game, too.
-Andy
Banned
Just need like a 1/4 inch spacer behind the pulley. That is if you move the alt up to where the compressor was before. My pulley is off i have the spacer just haven't had the time to put it in and line it all back up. So far i haven't blew a belt but the Golf is DOA at the moment till i can get a fuel pump
Re: Pulley alignment problems... (nweurosport)
I took the AC out of my car last year and I had to replace the water pump pulley and the crank pulley...I did not have to change the Alternator pulley..
Re: Pulley alignment problems... (Nash50)
For a stock look, you need a new inner crank pulley from a non A/C. Turn the water pump pulley around (it is the same pulley) and keep your P/S pulley as well as your outer crank. You will need that aluminum bracket to replace your steel one though as well as the hardware for it. New alternator belt.
2013 GTI DSG Stage 2
Re: (Pred)
Quote, originally posted by Pred »
yup, thats what i did. works pretty good when you move the alt to the compressor spot, looks good too!
1 - 6 of 6 Posts
