1 - 4 of 4 Posts
I want to possibly put some gauges in the dash section below the airbag on the passenger side. Anyone know what is behind this piece? I have a 96 Jetta without a glove box. I think I can see some screws so getting it of doesn't seem to be a problem.
Thanks, Ben
Re: pulling lower dash parts (badbennyb)
A metal plate is behind the bolster, and the bolster itself is galvanized steel covered with foam and vinyl. You can cut out the plate behind the bolster pretty easily (I just did to retrofit a glovebox), so you should have plenty of clearance for gauges. Just to let you know, VW advises against removing the metal plate, because it may change how the car's safety systems perform in an accident. Good luck!
[Modified by Zwoobah, 2:52 PM 11-26-2001]
1 - 4 of 4 Posts
