1 - 20 of 186 Posts
Banned
Greetings! As I have done with every other vehicle I have had, I am starting a timeline thread to help me keep track of progress. I am coming out of a 2015 Audi A4 Premium Quattro manual. I originally wanted an S in manual and Pure White / Marrakesh Brown but there is apparently only one left on the East Coast and the dealership in Virginia will not trade it to my dealership, forcing me to revert to Titan Black interior. Oh well; here you go!
Banned
Discussion Starter · #2 · (Edited)
Information
Vehicle Information
  • 2017 Volkswagen Alltrack S
  • 1.8T (170 hp | 199 lb-ft)
  • Six speed manual gearbox
  • Purchased from Young Volkswagen in Easton, Pa (29 July 2017)
  • LC9A Pure White
Current Odometer
  • 7,100
Engine/Transmission
  • Factory
Interior
  • OEM European light switch
  • OEM switchable hatch light
  • OEM auto dimming rear view mirror with Home Link installed, calibrated, and programmed
  • SiriusLED 3020 36mm festoon LED hatch bulb
  • OEM warning triangle in rear hatch
Exterior
  • OEM European aspherical mirrors
  • OEM Bumper Guard
  • OEM base carrier bars
  • Thule Canyon 859 roof basket (shared with wife's R32)
  • Curt 114223 Class 1 Trailer Hitch
  • Tekonsha 118730 Trailer Wiring
  • Lamin-x clear bra
  • Lamin-x door cup
  • Lamin-x yellow fog lamp film
  • Lamin-x clear head lamp film
  • Opti-Glass Pro
Lighting
  • Helix Golf R Headlamps
  • Hikari H7 LED kit
  • Hella Optilux H11 yellow fog lamp bulbs
  • The Bearded Detailer rear fog retrofit (adapter harness)
  • Cree XB-D (15W each) 7440R rear fog lights
  • Cree XB-D (15W each) 7440R brake lights
  • SiriusLED CK (17.5W each) 7440A rear turn signals
  • PerformanceLEDs (16W each) reverse light bulbs
Suspension
  • Factory
Wheels
  • 42 Draft Designs 15mm spacers
  • 42 Draft Designs 45mm bolts
  • OEM Interlago replicas; 18" x 8", et45
  • Nitto Motivo, 235/40ZR18 95W
  • OEM VW valve stem caps
Brakes
  • Factory
VAG-COM
  • VCDS: fog lights on with high beams
  • VCDS: instrument needle sweep
  • VCDS: driver seat heated seat retention
  • VCDS: passenger seat heated seat retention
  • VCDS: four brake lights (inner lights activated)
  • VCDS: passenger mirror dip with reverse
  • VCDS: remote windows open and close
  • VCDS: disable seatbelt chime
  • VCDS: disable door open/ignition chime
  • VCDS: DRL as option on MIB
  • VCDS: high beams and fog lights flash together
  • VCDS: independent European turn signals
  • VCDS: hatch open with remote
  • VCDS: rear fog light enabled
States Visited
  • Maryland
  • New Jersey
  • New York
  • Pennsylvania
Banned
Discussion Starter · #4 · (Edited)
To Do List
Listed are the parts that I want to purchase and add to the Alltrack. If it is red, then it has been ordered. If it is blue, then it is in my possession.
  • OEM Power Folding Mirrors: 5GG-898-207
  • OEM European lower engine cover: 06K-103-925-AA-KT
  • H&R 25mm Rear Sway Bar: ES2996789
  • ECS Hatch Kit: ES3046195
  • Opti-Coat Pro+
  • Lamin-x tail lamp film - tint
  • OEM Helix Subwoofer: 000-051-419
  • OEM European LED tail lamps
  • OEM 2018 Alltrack headlamps
  • Firestone Coil-Rite Air Helper Springs
Banned
Discussion Starter · #5 · (Edited)
Present and Past Vehicles
The vehicles that have been with me along the way. There are more but these are really the only ones worth mentioning.
My wife's 2008 .:R32 - Thread
My A4 - traded - Thread 1 | Thread 2
My Passat 3.6 - traded - Thread
My GLI - totaled - Thread 1 | Thread 2
My Jetta Coupe 2.0 ABA - sold - Thread
My Beetle - sold
Banned
Discussion Starter · #7 · (Edited)
looking forward to seeing what you do with it. You've had some nice past cars!
Thanks! I stayed pretty tame on the A4 because it was a lease. The Alltrack may be a little more extensive simply because I am losing a bunch of features that I have been used to. That, and VW stuff is cheaper than Audi stuff, haha. I will say one thing, it will not be bagged or lowered.
You say that now....... #bageverthing
Banned
Discussion Starter · #10 ·
I'm just glad you're not getting out of the r32, I was a little worried there.
You should know better! It'll be nearly impossible to let that car go. In two days, we will have had it for 6 years...I will need to replace it as a daily someday but never get rid of it.
Banned
Discussion Starter · #17 ·
I bet this one will be paint corrected and opti-coated in less then 10miles #beardeddetailerftw
I have instructed my dealership to not touch it other than a Pennsylvania inspection since it will be coming from Maryland. Hopefully the Maryland dealership didn't scratch it up badly but nothing I can't take care of. My dealership has also offered to swap front bumpers with one on the lot with no bumper holes. Perks of having worked there..I didn't even ask for that. :)
1 - 20 of 186 Posts
