21 - 40 of 119 Posts
Discussion Starter · #23 ·
Re: (crippled4life)
Quote, originally posted by Banana.Phone »
Damn, at first I was thinking the wheels would look like ass but they turned out well.
Can't wait to see the finished product.
Quote, originally posted by crippled4life »
interested, I like the 4 door. not feeling the wheels, but Nevada stand up!
LOL... Honestly I had my doubts too!
I figured if I didn't like it, I could always strip the powdercoat and just polish the lips. Thank God I liked the end result!
Thanks to Oscar33 for making my decision much more easier, I just placed an order for Bagyard fronts through Andrew. http://****************.com/smile/emthup.gif
Re: Putting hops in the Rabbit(MKV). (Aloha-boy)
wished the wheels tucked a bit mroe... But looks good so far..
what size/offset are the wheels? tires?
Discussion Starter · #25 ·
Re: Putting hops in the Rabbit(MKV). (Santi)
Quote, originally posted by Santi »
Thanks, me too! The fronts will tuck, but the rears will hit rim after I get it aired. I'm hoping a little camber will correct that though.
Size: 19x8 and 19x8.5
Offset: Roughly mid 30's(haven't accurately measured).
Tire: 215/35 all around.
Re: Putting hops in the Rabbit(MKV). (diive4sho)
i don't think i've met you before. did you just move to vegas? i'm gonna be baggin my mk2 soon i'd like to check your's out one day for ideas.
Discussion Starter · #30 ·
Re: Putting hops in the Rabbit(MKV). (dash cunning)
Thanks for the positive comments guys!
Quote, originally posted by dash cunning »
I had an '05 USP Avant when I moved here in '06. Sold it in '07 and quickly bought an '04 Touareg with Air. Gas kicked my but when it went up to $4/gallon and traded the Touareg for the Rabbit for me and Jetta for her. I missed the Air so bad and the fact that lurking in this forum, made me do it!
I should be done with my install at the end of summer, so I'll hit you up later.
Modified by Aloha-boy at 11:43 AM 7-22-2009
Discussion Starter · #33 ·
Re: (andrew m.)
cigarnut81 - Thanks man!
EurodriverMK3 - No problem, glad to help!
Quote, originally posted by andrew m. »
errol, here's a little taste of whats coming your way.
andreas is a genius when it comes to graphic design.
your bags shipped out this week,, i'll email/pm you the tracking
information http://****************.com/smile/emthup.gif
SAWHHEEETTT!!!
LOL... Andreas is very clever! http://****************.com/smile/emthup.gif
Looking forward to your email/pm.
Discussion Starter · #35 ·
Re: Putting hops in the MKV Rabbit. (Aloha-boy)
Being a daddy of 2 boys(5&2) and wife going to school fulltime, winter projects were at a stand still. Now that the wife is on break and the weather warmed up, I was able to put in some work.
I finally chose a final box design and mounted all of the components on Friday night.
Saturday I ran all my power and controller wires down the driver side rail. I chose the cubby compartment, under the headlight switch, for the controller. I also left a lot of the slack for the controller in there. I did it so I can take the controller out and control the car from about 4-5ft from the dirver door. Here is the driver's view of the controller in the cubby.
Saturday night, after watching Twilight New Moon with the wife, I tried to work on cleaning up the wires in the box. But when my drill slipped I nicked my left thumb with a hole bit. I would've taken a picture, but I was in shock and decided to end the night.
Question for the MKV guys: What fuse did you tap for the Auto Pilot brain?
Here's my "left to do" check list:
- Connect all the power wires and do a system check.
- Install rear air bags and run rear air lines.
- Notch, install front air bags and run front air lines.
Modified by Aloha-boy at 9:19 AM 4-14-2010
Discussion Starter · #38 ·
Quote, originally posted by tomespo »
Under the dash go to te 75x for the autopilot it's switched power just put a 5 amp inline fuse
I think that's for the MKIV, but thanks! http://****************.com/smile/emthup.gif
MKV guys what fuse did you tap for the Auto Pilot brain?
