Re: putting scoop on hood, best way????? (2LMONSTER)
If the scoop was fiberglass, then it would be easy. I'd pretty much say don't even try to mold ABS and metal together. It won't work very well, and it'll crack very easily. Same goes for fiberglass actually, it's better to use metal and weld it on. You'll have a solid connection that won't crack.
Go to a junkyard and cut up a car with the scoop you want, or buy a pre-made metal one. It'll be less trouble in the end for a better result.
