Re: Question about 1.8t power stage output module? (killerdub)
Quote, originally posted by killerdub » |
I thought maybe it reads temperature of some type being that it is mounted on the airbox on stock cars. What do you think? |
Nah, it's just an ignition signal amplifier, but like the output stage on a high power audio amplifier it will generate alot of heat and needs to get rid of said heat or it will fail, make sure you mount this thing to a piece of aluminum, or a heat sink (like the original), and use a dab of white heat sink compound between the back of the module and the aluminum heat sink, you can get the stuff at radio shack.
After that, just mount it where in the best place that the harness will allow (ie, away from heat!). The AEB harness isn't exactly "tailored" to the transverse install, good luck. http://****************.com/smile/emthup.gif
