Question about 4-motion rear valence - please help!
534 Views 8 Replies 6 Participants Last post by  turbocharged
Does a 4-motion rear valence fit on the U.S. spec rear bumper, or would it need to be converted to the European spec rear bumper?
Thanks for any help
See less See more
1 - 9 of 9 Posts
Re: Question about 4-motion rear valence - please help! (turbocharged)
The valence fits NA bumpers...I'm pretty sure. You need to cut away a piece of sheetmetal though. Look for Roger Moore's site, he has instructions there. http://****************.com/smile/emthup.gif
See less See more
Re: Question about 4-motion rear valence - please help! (MatchStick)
Ummm. Ok say one link says that I don't need to do anything and the other shows that some sheet metal needs to be cut out. So What's the story - direct bolt on, without any problems at all, or will I need to do some cutting?
Thanks
See less See more
ttt
It's a direct bolt on but you need to trim some metal like it says in this link on Roger Moore's site. http://bambergvr6.freeservers.com/golf_iv_rear_4.htm
[Modified by EPilot, 9:45 PM 2-8-2002]
quote:[HR][/HR]Ummm. Ok say one link says that I don't need to do anything and the other shows that some sheet metal needs to be cut out. So What's the story - direct bolt on, without any problems at all, or will I need to do some cutting?
Thanks
[HR][/HR]​
If you read the sites they are both the same.....both indicate that the valance requires no modification to fit the US rear bumper. What Roger Moore's site says is that you need to remove the metal part so that its not in view from behind the car......
guess I should indicate that on my site too
stu
See less See more
Re: Question about 4-motion rear valence - please help! (Boostin20v)
ooh. Alright now I understand - guess I was a bit confused!
1 - 9 of 9 Posts
