My understanding of the synchro trans as fitted to B3 and B4 (Europe) is that the front drive is much the same as the standard front wheel drive, but that there is a power take of on the back of the trans, to which a viscous couple drives a prop shaft for the rear wheels.
In other works there is no centre diff, and the front wheels are always fully driven and connected to the output of the gearbox.
So, when dumping the clutch on a slippery road, do you get a moment of front wheel slip before the viscous coupling locks up enough to drive the rear?
I guess that the front has to slip a bit before that coupling sees a speed difference from input to output and transfers any power.
What affect does this have on drivability?
What about when you stomp on the gas mid way around a slippery corner? Does the front break free for a second until the back end catches up?
Also how much power / economy do you loose due to the extra prop shafts and stuff?
Is this the same system basically as Audi Quattros?
