1 - 10 of 10 Posts
I have a obd1 vr6 12v engine, i also have a obd2 Shrick Manifold.
I know they TB's holes are different and i have searched and searched for a adapter but cannot find one.
Any one have any ideas or leads?
One company said they may be able to just sell me the TB part of a obd1 Schrick Manifold but they have yet to find one for me.
I dont currently have the time or resources to machine one.
Re: Question: Need to fit a obd1 TB onto obd2 schrick manifold (selfatvi)
I run a OBD2 Schrick on my OBD1 and it wasn't hard at all. I used an OBD2 tb and just wired in the OBD2's tps into the OBD1 wiring. The 5v/ground wires were backward from what I thought they'd be on the OBD2 but other then having to swap them I had no issues. I retained the stock OBD1 ISV due to the OBD2 still having that port available on the side. I also had to delete the EGR but that wasn't hard either. Any other questions, just shoot.
Discussion Starter · #4 ·
Re: Question: Need to fit a obd1 TB onto obd2 schrick manifold (need_a_VR6)
Quote, originally posted by need_a_VR6 »
Did the holes align? Or did you modify the TB in any way other than the wiring?
I may go the simple route and just buy the above linked adapter plate if he still makes them just in case i ever take off the manifold i dont have to find another TB which would be the same cost as the adapter.
I used an OBD2 tb so it bolted right on to the OBD2 Schrick. The wiring I just had an OBD2 ABA harness that I cut the plug and wire pigtails off of to wire it in.
The adapter would probably be cheaper if you don't already have an OBD2 tb sitting around.
Discussion Starter · #6 ·
yeah, my car is obd1, so the TB is obd1. My manifold is obd2 so the TB portion the holes do not align up.
I want to use the TB as is but i need and want a adapter to mount it to the obd2 manifold.
Car: OBD1
Manifold: Obd2
I know exactly what you're saying, and that's exactly what I have. OBD1 engine management, OBD2 Schrick manifold. I used an OBD2 tb with some wiring mods. I'll try and take a picture later.
Discussion Starter · #8 ·
cool, love to see it.
At first i did not understand but now i do, you re wired the OBD2 TB to work with the OBD1 setup.
Any issues with the length of the throttle cable?
Modified by selfatvi at 11:12 AM 3-21-2008
Modified by selfatvi at 11:13 AM 3-21-2008
Discussion Starter · #10 ·
No mods to the tb cable bolted right on.
Cool, goign to the yard this weekend to look for a obd2 TB.
Thanks for the help. Still would much rather have the adapter but i cant find anyone who makes it despite the above thread.
Stupid $1200 paperweight
1 - 10 of 10 Posts
