I got everything hooked up... But how do I test if diode mod works? I'm riding around and I try the switch in all 3 positions, I can't tell the difference. Also, do I have my MBC hooked up right? I just replaced the N75 with the MBC, wga line to mbc, and that other line (coming from the intercooler piping i think?) to the mbc.. and blocked off the intake side where the N75 was connected to..
I'm asking if this is right because, when I turn the MBC all the way down, I have unlimited boost... Like the wastegate won't open.. and when I turn it a couple clicks up, I have 10psi, then a couple more clicks up, i'll have 6 psi, then a couple clicks more i'll have 4psi.. but if I turn it down, it goes up to about 14psi untill i run out of clicks and i'm back to unlimited.. I tried switching the hoses to the MBC thinking they were backwords, same thing happened. Is it cause it's a cheap controller? I have a feeling i'm running these lines wrong..
Modified by Anthony1.8 at 8:41 PM 10-30-2008
