APR was at ECS Tuning today, so I made the drive up (with a couple of other Vortexers
) to have my 337 chipped.
First of all, this is a fantastic mod. The car pulls amazingly through each gear and the power seems endless. It's a huge improvement over stock and well worth the money.
My only critique is that I experienced a fair amount of surging, especially in 5th and 6th gears. The surging was most noticeable at 1/2 throttle or when I would abruptly lay off the gas. So like a good little Vortexer, I hit the search function hard trying to find a solution.
Some of the posts I've read (like this one: http://forums.vwvortex.com/zerothread?id=354538) indicate that replacing the stock F N75 valve with an older C N75 valve has eliminated surging altogether in some applications. I have also read posts that indicate that the ECS Tuning N75 valve is another surge fixer.
Now the questions:
1) Would/should this N75 swap work on our 337s? I haven't read any posts from 337 drivers that have done the swap.
2) How difficult is it to replace the N75 valve? None of the posts I've read go into much detail about the job.
The surging issue is just one of those tradeoffs for more power, but I'd love to try and solve the problem if at all possible. Thanks for any help you can give.
[Modified by Justin @ 3 Rivers VW, 11:10 PM 9-26-2002]
Now the questions:
