Quetion about 3rd gear??
522 Views 9 Replies 7 Participants Last post by  kiyi888
Lately when I go to put the car into 3rd gear it makes this awful noise...like this grinding sound. Someone help, its just a 98 it shouldn't already be doing this its just a baby.
See less See more
1 - 10 of 10 Posts
Re: Quetion about 3rd gear?? (98GTIchick)
Do you have a VR6 or a 4 cylinder?
Sean
Re: Quetion about 3rd gear?? (EuroStyle)
A 4cylinder
Re: Quetion about 3rd gear?? (VAGtuning)
The clutch is all the way in.
Gotta luv those VW tranny's
See less See more
Re: Quetion about 3rd gear?? (ramondvw)
Does anyone know about what's going on???????????
See less See more
your 3rd gear syncro is probably going.. try changing the transmission fluid to Redline MT-90 and it will probably help stop the grinding. it did on my 2.0 (2nd gear)
you can get it at http://www.parts4vws.com
jeff.
2
quote:[HR][/HR]Lately when I go to put the car into 3rd gear it makes this awful noise...like this grinding sound. Someone help, its just a 98 it shouldn't already be doing this its just a baby.
[HR][/HR]​
Baby? My '98 needed a tranny rebuild and a new clutch after only 37k miles... http://****************.com/smile/emthdown.gif Not sure what your problem is... But it does sound like a syncro since the other gears aren't crunching too.
See less See more
Re: Quetion about 3rd gear?? (JettaGLS)
I've heard also that when you grind second you have to adjust the shifter. There is a website for this, also in the bentley if you wanted to look at that as your options.
Re: Quetion about 3rd gear?? (Gazabomb)
hi, i heard that you had your tranny rebuilt. I am having problems with my gear popping out, i was wondering where you had your tranny rebuilt and how much did it cost...i'm in desperate need of fixing my car! thanx
1 - 10 of 10 Posts
