does any one know what is spouse to be use to hold round head lights onto the rad support (just got new lights and rad support and it didn't come with any thing) thanks
The outer lights are bolted on the rad support. If you have quad rounds the inners are mounted on to the grille with screws/bolts. Then the grille just, obviously, pops in with tabs. You should be able to use whatever bolts are on your existing setup headlights on the new ones.
ya i'm swaping to a dual round set up, but the rad suport didn't come with screws and my new lights didn't eather....wasn't sure if there was some crazy nut and bolt set to use or is just regular bolts would work
no the lights are mounter onto some bracket thing, i'm just woundering what i need to hold that onto the rad suport(screw/bolt wise, and if rubber busshings or any thing is needed)
i'll send the e-mail after this post, and i had the areo set up, and i am swaping to dual rounds becaus i like the look better, and think it's a cleaner look
1 - 14 of 14 Posts
