Why wouldn't it be, as long as is rated for the weight of your vehicle. They have a 3500,5500,7000 lbs models.Can anyone confirm if any of the Quickjack models is compatible with a TT-S?
Take a look at this link then:I’m concerned about geometry, not weight. Just want to make sure that the jack points line up with the jack.
I don't have those red pucks shown earlier in the thread, I am just using two normal rubber blocks that are approximately the same size as the stock jack-points, it works OK. Not the best picture but here the car is lifted on the quick-jack:@Iqbad - are you using the side sill locations with pucks? Also, any chance you have a picture?? Thanks for confirming!
Thank you!!!I don't have those red pucks shown earlier in the thread, I am just using two normal rubber blocks that are approximately the same size as the stock jack-points, it works OK. Not the best picture but here the car is lifted on the quick-jack:
