1 - 1 of 1 Posts
Discussion Starter #1
I now have racing axles for MK 1, 2, 3 race cars for sale. The specs are; 100mm flange, 4130 inner cages, Loose fit balls, 90mm outer CV, loose fit outer cages/balls, slightly shorter shafts. good grease , new boots. These have been tested on the Chumpcar and the welded diff Rocco. Time between service looks to be around 20hrs.
The cost is 400$ per set ( plus cores) and includes the FWD racing guide . This PDF book explains how to keep the axle/ engine centered so as not to bottom the cages,destroying the axles.
Thanks, MM
1 - 1 of 1 Posts
