Read a bit on these but for those that installed do they work well? Do they hit the coolant resevoir? Is installation as easy at it looks on youtube?
This one is 30$ less than the racing line one... anyone tried it yet?Is there any benefit in putting the MK7/MK7.5 OEM version in? I think it is this one?
VW OEM MK8 GTI/R Hood Gas Strut RetroFit Kit
wctperformance.ca
Does not fit on my 2022 R hits the coolant tank.Read a bit on these but for those that installed do they work well? Do they hit the coolant resevoir? Is installation as easy at it looks on youtube?
It doesn't hit the coolant tank on my NAR Golf R, but it does rub up against the coolant reservoir return hose. I've fashioned a bodge out of the VW parts bin.Read a bit on these but for those that installed do they work well? Do they hit the coolant resevoir? Is installation as easy at it looks on youtube?
Thank you very much. I have minimal auto skills. Is it easy to loosen and tighten back that reservoir hose clamp?I had the rub too. I just loosened the hose clamp on the reservoir and rotated the hose about 15* so it sits pretty much as @TheRealDL posted. No more rubbing. To answer your question, I would buy it again. If you're spending any time under the hood, checking your oil, etc. it's well worth it IMO.
Good to know! I ordered one as well but it has not arrived yet. Some of these posts had me concerned I was wasting money.I had the rub too. I just loosened the hose clamp on the reservoir and rotated the hose about 15* so it sits pretty much as @TheRealDL posted. No more rubbing. To answer your question, I would buy it again. If you're spending any time under the hood, checking your oil, etc. it's well worth it IMO.
Yes. Pliers or maybe your fingers if your grip strength is good enough. Pinch the clamp, turn the hose, release the clamp. I'd say removing the nut on the hood latch hook and tightening the ball nut is more difficult (but not difficult). The latter is loosening a nut and tightening a different nut on the same bolt. Entire install with the coolant hose tweak is a 1-2 on a scale of 1-10. If you can turn a wrench or own a socket set that you've used more than once, you will be fine.Thank you very much. I have minimal auto skills. Is it easy to loosen and tighten back that reservoir hose clamp?
