Re: Radiator Fan not working any common problems? (Der KdF)
Did you check the wire harness plug that plugs into the fans. if the little locking tab is broken the plug might slip loose? Like stated above, I also had to have the module replaced. If I remember correctly, the module was a dealer recall, so the dealer did not charge for the part, just labor.
Modified by corradomania at 3:33 AM 9-11-2005
