1 - 4 of 4 Posts
Car has been smelling like burned plastic for the past 2 days. Ran it for codes and this is what came up.
Code P069100 Control circuit low.
P195100 fan has difficulty moving/blocked.
P194800 Control module 2 fan activation/ short circuit.
Anyone know what I need to do to fix it?
Thanks!
I think the main (larger) fan might need to be replaced. I had a similar experience when mine died. The smell is probably coming off the fan control module over heating or the fan motor. The fan control module resides inside the main fan housing itself so it will be replaced when the main fan is replaced.
Sent from my Nokia 3.4 using Tapatalk
Discussion Starter · #4 ·
Faults -P048000 - Cooling Fan 1 Control Circuit
static
Date: 2091-12-17 01:13:12
Mileage: 236808 km
Priority: 2
Malfunction frequency counter: 1
Unlearning counter: 255
Engine speed: 1300.50 1/min
Normed load value: 11.0 %
Vehicle speed: 0 km/h
Coolant temperature: 39 °C
Intake air temperature: 24 °C
Ambient air pressure: 1000 mbar
Voltage terminal 30: 13.984 V
Dynamic environmental data: 209628110E0211EC0111DC000B11ED3610A601D011EE2911DB0313
P069100 - Cooling Fan 1 Control Circuit Low
Intermittent
P195100 - Coolant fan 2 difficulty of movement/blocked
Intermittent
P194800 - Coolant Fan Control (FC) Control Module 2, fan activation Short circuit
Intermittent
Mileage: 236810 km
Date: 2021-10-18 21:17
Fault
Control unit: 03 Brakes
Active faults: 0
Inactive faults: 1
System description: ESP MK60EC1
Software number: 1K0907379BL
Software version: 0152
Hardware number: 1K0907379BL
Hardware version: H31
Faults:
01325 - Tire Pressure Monitoring Control Module No signal/communication
Intermittent
Priority: 2
Frequency counter: 2
Driving cycle: 57
Mileage: 236335 km
Mileage: 236810 km
Fault
Control unit: 08 Air Conditioning
Active faults: 0
Inactive faults: 1
System description: Climatronic
Software number: 3AA907044BH
Software version: 0404
Hardware number: 3AA907044BH
Hardware version: H03
ODX name: EV_Climatronic
ODX version: A01010
Faults:
U111300 - Function limitation due to received malfunction value
static
Date: 2091-12-17 01:13:17
Mileage: 236808 km
Priority: 6
Malfunction frequency counter: 5
Unlearning counter: 28
Mileage: 236810 km
Fault
Control unit: 09 Central Electrics
Active faults: 0
Inactive faults: 1
System description: BCM PQ35 M
Software number: 5K0937086R
Software version: 0173
Hardware number: 5K0937086R
Hardware version: 122
Faults:
01598 - Drive battery voltage Open circuit
Intermittent
Priority: 6
Frequency counter: 1
Driving cycle: 47
Mileage: 236332 km
Anyone know how much its gonna cost me to fix theses issues? 🤔
1 - 4 of 4 Posts
