Quote, originally posted by silverroco » |
I suppose you are talking about the expensive upper hose that goes to the block and reservoir? How is the alternator causing a problem?? It has a molded "rub pad" that sits on the radiator and should never come close to the alternator, maybe you need to rotate the hose so its more upright, and how is deleting the AC going to help unless you move the alternator down?? |
