I am rewrapping some wiring and after pulling off all the old tape I noticed this. Two R/W wires joined together. One goes to the radiator fan connector and the other goes to the radiator thermoswitch. Someone had already done some work in this area, so this appeared to me to be some kind of hack or mistake. But then looking at the wiring diagrams, I'm starting to wonder if it's factory correct. Anyone know? Also noticed the factory put solid plastic sheathing material in two places that I never noticed before, then covered those in tape. I assume that was to deal with heat or something.
Here's the wiring in the car:
And then as you can see there is a junction of two R/W wires in the diagram, so this may be factory correct and I should leave it alone. The symptom I was having was the rad fan would come on sometimes many minutes after the car was turned off, and would only run for a brief few seconds, then turn off or turn on and then turn off so quickly the fan hadn't even got up to speed yet. So something funky is going on. Might be the thermoswitch itself, or the wiring and this curiosity is what I found.
Here are the sheaths. I don't think these are used anywhere else on the car, at least I've never seen them used anywhere.
Another oddity is this junction of two R/B wires to a single R/B wire. Not sure if that's factory or not.
