1 - 10 of 10 Posts
Moderator
Discussion Starter #1
If you have a question about your radio, such as which unit you have, the tech specs for the radio, does phatnoise work with my radio, etc, follow this like to find some useful info prior to posting:
http://www.ibiblio.org/tkan/au....html
That also includes instructions for entering your radio code if you do not have your manaul for refrence. If your radio is in safe mode and you don't have the key, you will find useful info here:
http://forums.vwvortex.com/zerothread?id=3752897
After you look through the first link, and check the 2nd link if applicable, if you still have a question post it in this thread for help to get your answer or directed to the proper place.
Modified by robbyb413 at 8:07 AM 10/3/2008
Re: Radio Question? Start Here. (robbyb413)
Does anybody have pictures of the concert 2 in their b5 and any advice for putting the thing in my dash.
Re: Radio Question? Start Here. (Deathbot-b5)
question:
what, if any, other magazines will work with the OEM alpine cd changer that works with the delta CC radio?
i have the OEM part #, any idea if a clarion magazine will work?
Quote, originally posted by Deathbot-b5 »
i want to see that too,
i'm debating switching back to an oem head unit from this old ass alpine, because the colors do not match http://****************.com/smile/emthdown.gif
Re: Radio Question? Start Here. (Lazer Viking)
Im having issues with my Concert radio on my 97, when I hook it up its is SAFE mode, ok, thats fine. I press FM2 and RDS but the numbers never flash...ergo I cannot input my code.
thoughts?
Will a Newer Audi Deck work?
I currently have a tape deck in my 98 A4, and im looking to buy an Audi concert CD deck from a 2004 TT, anybody know if it will plug in?
My current tape deck:
2004 TT Deck:
Re: (GregN96)
Quote, originally posted by GregN96 »
Check the wires in the back to see is they match.
If i had both decks in my possession, I would have given that a shot. Thanks.
Re: (xlmasonx24lx)
the concert 2 out of a TT is nominaly the same, the radio should plug in, the issue isthat its a can bus radio so you won't hev ilumination, or igition controlled on or off unless you get a cam emulator
1 - 10 of 10 Posts
