Re: Raising TDI compression (A2RicedGTI)
Raise the compression ratio???
IDI pistons are flat on the crown. They will absolutely NOT work with the TDI.
Also, raising the compression ratio beyond a certain point causes a WORSE surface to volume ratio, worsening heat transfer losses. I would say that at 19.5:1 compression of the stock TDI, it's already near that limit where increasing the compression ratio will not significantly increase the temperature at the end of compression.
I hate to discourage you, but I think E85 will not work adequately on a true compression ignition mode without a Diesel pilot ignition or at the very least, glow-plug assist. The Methanol fueled research engine that I mentioned before based on the TDI with 20:1 compression is spark-ignited to give you an idea oh how difficult it is to autoignite alcohol fuel. Ethanol autoignites 973 degrees Fahrenheit; adding gasoline to the blend will reduce it only marginally. By comparison, Diesel fuel autoignites at about 600 F or 33% less. This means your end-of-compression temperatures, at the most simplistic level, need to be FAR higher than 973 F.
Your team has some VERY ambitious ideas for a powerplant for which I applaud you, but might I suggest again that you address the fundamentals rather than trying to reinvent the wheel with the realistic resources you have?
