1 - 3 of 3 Posts
VAG-COM Version: Release 303.1
Control Module Part Number: 06A 906 032 DL
Component and/or Version: 1.8L R4/5VT G 0003
Software Coding: 07500
Work Shop Code: WSC 09456
3 Faults Found:
17608 - Boost Pressure Control Valve (N249): Mechanical Malfunction
P1200 - 35-00 - -
17511 - Oxygen (Lambda) Sensor Heating: B1 S1: Performance too Low
P1103 - 35-00 - -
16517 - Oxygen (Lambda) Sensor B1 S1: Response too Slow
P0133 - 35-10 - - - Intermittent
So i am guessing that i am loosing an O2 sensor but not sure which one
also I have apr stage3 and I am using a greddy type S with the recirculation kit for a DV
Vendor
ID.4, 997.1
Re: Ran vagcom and these are my error codes (Krystaaldub)
The DV isn't acting like a stock DV. Your front O2 sensor (or the wiring to it) is on its way out.
Re: Ran vagcom and these are my error codes ([email protected])
Thanks Andy
I have heard you are the man when it comes to vagcom
do you have any dealings with the geddy type S DV with an upgraded turbio, any suggestions, I have gone through a stock DV, Forge DV, and now this one.
1 - 3 of 3 Posts
