1 - 7 of 7 Posts
Discussion Starter #1
What mods do you have in the dash if any? Have you taken it apart ever? Also what kind of vibrations do you get while on the gas if any?
Discussion Starter #3
No dash mods never took it apart for anything. No vibrations.
Does this only happen while turning the wheel?
Have you started pulling all of the trim off the dash to see if you can isolate a specific area that it is coming from? If not, that is where I would start.
Discussion Starter #5
Nope just everything I let my foot off the gas.
I've been trying to listen to where it might be coming from but I haven't been able to confidently confirm the spot. Don't want to start taking things apart and put it back together after a dead end you know. Could it be my wastegate? :confused:
Are you hitting and kind of bumps, hard to believe there's rattling with no cause of movement. When your on the pedal it doesn't do it???
Discussion Starter #7
Thats right. I'll be in gear with my foot off the gas pedal and it would start but go away as soon as I put my foot back on.
1 - 7 of 7 Posts
