Hello. I am putting this together to save people wanting to retrofit this radio a whole lot of time. This retrofit requires a little bit of vw and electrical knowledge.
This relates to the 187B "no name" with CarPlay model. May or may not apply to the Dessay brand one. Also, this pertains to North American cars as I do not know anything about ROW cars.
First, to set the expectation... this radio is fantastic. It is a great upgrade for those with the base radio. It is not a RNS "like" unit, but CarPlay is life changing.
So, here we go...
1. Is it plug and play?
No. It may look like it on 2015 and older but it is not. The 12 pin blocks are not pinned the same. I recommend repinning the wires on a new quadlock. I used a Scosche VW03RB. It is cheaper than getting one of those harness things and looks better.
Radio wire blocks are the same, power and can are the same. If you are retrofitting this to a 2016+ car you are going to have to move things around and get creative. I had to made some mini harnesses for the can and power as they are not the same size.
The 12 pin block under the speakers is for the camera. It is a component camera connection. Pin 6 is positive and pin 12 is negative. See next question about cameras.
The block under the power and can is for a mic. Pin 1 is negative and pin 7 is positive.
2. Will my factory rear camera work?
No. On 2015 and older you will need a RGB to CBVS adapter. On 2016+ cars, although the cameras are component, they just plain do not work with the 330.
I recommend replacing it with a good aftermarket RCA camera. You can purchase one that fits and looks just like my factory camera in the trunk handle.
If you are replacing a 2015 or older camera you will probably also need to purchase or make a delay timer. Check aliexpress. The 330 requires power to the camera for 8 seconds after shifting out of reverse or you will get a error on the unit.
For 2016+ cars you can use the factory connections the old camera connected to. No timer or anything needed.
I actually disassembled my factory lock handle and replaced just the camera. A Metra BBBPC camera fits perfect.
**Edit** although this woeked, the angle was all wrong so I replaced the entire handle with an aftermarket handle camera (see below).
3. I have a car older than 2012iah, what do I need?
You will need to upgrade your CAN gateway or purchase a canbus simulator specific to the 330. If not, your battery will die... or the radio... or both.
4. Coding this thing?
The proper coding for the unit is
16 00 04 40 00 05
40 at block 4 enables the reverse camera.
If you have Fender change block 2 to 01. If you have Dynaudio change block 2 to 05. On either you will also have to change block 3 to 00.
I used a OBDeleven and had to go to Radio-56, switch to development mode in service to change block 2.
In all aspects of coding our NA VW's consider these to be RCD-510's and you can use the same code labels in VCDS.
5. What about steering wheel controls and Dash screen?
On 2012+ cars all controls work fine. As long as you have 6 or more buttons per side. Older cars will need a canbus simulator.
There is no Center screen display of anything on any car. Don't know why. Don't care because I never used it.
6. What else should I know?
If you have a factory media thing in the glove box or console, it will not work. Remove it and sell on eBay. Same with CarNet.
If you had Bluetooth prior to switching to the 330, go under the passenger seat and remove the Bluetooth module and sell it on eBay. It will interfere with the 330. You will also have to code the old Bluetooth out of the gateway.
If you have a external USB or aux in. Sorry, it won't work. My 2017 Passat has a single USB in front of the shifter. I retrofitted it to be a power only USB by removing the old USB plug, taking it apart. I found that the innerds of a TomTom GPS cigarette USB adapter fits perfectly inside the old plugs plastic housing. From there in tapped power from the cigarette lighter.
Summary. For most it is a pretty easy upgrade especially if you are coming from a base model. If you care about cameras And extra stuff it is going to be a challenge.
I have a 2017 Passat that I removed the base composition color. I spent about 30 hours on research and installation. My system works like a friggin charm. It can be done and it is amazing.
So, here we go...
16 00 04 40 00 05
