Please help:
I used an OBDEleven Pro to do the exact change as suggested blow, to make a Desay 187B working with Fender sound system, but I cannot modify any Byte in Radio-56. Instead I consistently got a red pop out message at the bottom of the screen saying:
[33] access authorization required, perform login
I am sure the OBDEleven app was logged in with the Pro account. What's going on here? Anywhere else I need to check?
By the way, both Fender sound system (Amp + speakers) and the 187B are retrofit. The original car came with the lowest trim (Trim S).
4. Coding this thing?
The proper coding for the unit is
16 00 04 40 00 05
40 at block 4 enables the reverse camera.
If you have Fender change block 2 to 01. If you have Dynaudio change block 2 to 05. On either you will also have to change block 3 to 00.
I used a OBDeleven and had to go to Radio-56, switch to development mode in service to change block 2.
In all aspects of coding our NA VW's consider these to be RCD-510's and you can use the same code labels in VCDS.
