1 - 5 of 5 Posts
So i decided to grab one of those RCD330+ Headunits and it came and i noticed it had a fuse in the back where i have one grey connector with two wires, orange/green and orange/brown, that plugs in there. I did some research and i’m having trouble locating any other headunit with the same thing. did i just get the wrong headunit ?
With fuse is the correct one.
Here is mine:
yeah it seems as if everyone has these but my jetta came with the one without the fuse so i’m confused 😂. any idea on how to repin those two wires ? or what they are for? i was reading that they could be illumination wires or can bus wires.
82638
Circuit component Computer keyboard Electronic instrument Automotive lighting Gadget
Are you sure the headunit is not a fake one?
Have you tried it?
Without full installation, check the functions.
Maybe the fuse is built in on board.
2014 Jetta GLI
The rear of your
Here is mine:
The layout of rear pins on your headunit are for MQB, and not for PQ35 platform. The 2 large flat pins on the right-hand side of the Quadlock plug are for GND and BAT. The 2 small pins you are asking about are for CAN+ (Pin 6) and CAN- (PIN 12).
1 - 5 of 5 Posts
