Really hard to shift!! Help!
386 Views 4 Replies 5 Participants Last post by  98JettaGT
I bought a 97 GTI 4cyl last year, which had some modifications. The shifting was real stiff, sometimes I am not able to put it in 1st or 5th.. So I pulled off the GLUED ON Momo knob, and saw that the stick had just been cut down. I understand that since its shorter, there is less leverage, but it is almost impossible to drive. Anyone have an idea what I need to change to make the car shift nicely?
thanks for any advice you can offer
See less See more
1 - 5 of 5 Posts
Re: Really hard to shift!! Help! (xxgtigirlxx)
go punch whoever you bought it from... that helps a little
where in miami are you from?
Get the linkage adjusted. I had the same problem with reverse, 1st, 3rd and 5th gear. Notice all your trouble gears are on the upper side. Also get your gearbox checked out.
You can also try the following:
1. Changing the tranny fluid MAY help
2. You can spray some WD-40 or similar on the linkages, that may smooth things out a bit. The linkage is down below the brake master cylinder and a little to the left if you are standing in front of the car.
Most likely your linkage is in need of adjustment. While a shortened lever reduces your leverage, mine is chopped down ~2" and it's very easy to get in gear.
1 - 5 of 5 Posts
