1 - 4 of 4 Posts
what I thought was a bad wheel bearing is actually the caliper touching the disk...
there is plenty of pad left, so whats wrong with it? and how would I go about fixing it...
Discussion Starter · #2 ·
Re: rear brake caliper touching the disk (G60teknik)
took the rear wheel off only to find the actual rotor was loose. removed the grease cap, to find that the nut had managed to back off...
tightned up. so all seems happy, for now
Did you put that nut cover and cotter pin back in? That is what keeps the nut from backing out
Discussion Starter · #4 ·
Re: rear brake caliper touching the disk (CorradoKidd)
yes....
what do you think I work at VW or something....
1 - 4 of 4 Posts
