1 - 6 of 6 Posts
I need to replace my rear brakes on my 2000 4Motion. I understand that I need a special tool to retract the brake cylinder. It is threaded??? Any comments?
Re: Rear Brakes - Special tool??? (d2x/dt2)
Normaly you can get pistons back in, by rotating it (using example big pliers).
If brake pistons are too out, then you maybe need special tool.
Banned
All cars with rear disc brakes that use the disc for the e-brake, need the piston rotated as it is retracted into the caliper. A special tool makes it more convenient, but is not required.
Re: Rear Brakes - Special tool??? (NC-GTI)
I used needle nose pliers and took 1 hr on one side and 15 min on the other... making sure the rubber boot wasn't torn.
I would buy that tool!
Try an Autozone parts store. They will rent you this tool for FREE. You will have to put a deposit on the tool of about $35.00, but the money will be refunded when you return the tool.
[Modified by dbarry2, 12:03 PM 5-31-2002]
Re: Rear Brakes - Special tool??? (pipes)
Do you have to open the brake fluid line in order to push cylinder back with the tool /or without?
How should I turn the cylinder - clockwise or counterwise?
[Modified by Odesssa, 1:44 PM 6-15-2002]
[Modified by Odesssa, 3:54 PM 6-15-2002]
1 - 6 of 6 Posts
