1 - 9 of 9 Posts
I have a non-auto euro switch with front/rear fogs. I don't plan on putting in rear fog lights so I have an idea: could I possibly use the empty pin on the plug (for rear fog) and route it to my own relay to add my own accessory lights? That way they will be controlled by the switch instead of using a cheap looking aftermarket one.
Thanks! I really want to avoid drilling a hole somewhere on my dash and putting a tacky switch. I like to keep things reversible haha
Great thinking! I may have to utilize this idea as well... let me know what pin you get that fits inside the plug that goes into the headlight switch please.
Discussion Starter · #9 ·
Update, used a generic yellow repair wire from ECS, pin 7 on the small-plug headlight switch. Wire a relay as you would to battery, ground, accessory to be turned on, and switch (trigger wire from headlight switch). Did a test run on a friends mk6 GTI, works flawlessly!
1 - 9 of 9 Posts
