Saw the transmission had sweated some fluid out on to the drivers side axle. I had a level check performed on the fluid. It was lessening, so I had the seal replaced. The mech also noticed the right rear shock was leaking oil. I hummed and hawed, boge turbogas? or bilstein? ( at twice the price ). Any how I used the bogie's because of my mechanic answer. You can't feel the difference, " with ordinary use as long as gas pressurized on the rear and you will be fine. Any how ..... After a drive home let me say I am more than pleased. My great big bounce around after market exhaust no longer has a rebound bump and grind. Yippeee!!!!!
