21 - 40 of 53 Posts
biglilsteve, did you install the plate butted up against the lip that hangs over the top license plate area. My dealer installed mine 3/4" below it and was wondering if that was normal or if I should push it all the way up?
BWN
Yeah it's butted all the way up. The plate looks like it would overhang if you don't.
Get the volvo mount and some 3m dual lock velcro at a hardware store and be done with it. I did not want to punch holes in the bumper and the velcro solution solved it and also makes it easy to pop plate and bracket off in one step for cleaning behind it. I will get a pic of it later today.
Why concerned about holes in the rear bumper? It's always going to need a plate there.
Sent from my ONEPLUS A5000 using Tapatalk
Golf R
Or, no bracket at all! Just use Heavy Duty Velcro (2 strips 4" long X 2" cut to 1" wide) plate to bumper - plate is removable as required, won't ever fall off - Velcro is used in commercial airliners to secure interior panels to the structure:
Careful with that stuff... it has a maximum operating temperature. Thereafter, the glue says "I'm done". :(
You guys are crazy.
License plates are always required. The paint behind them will never be seen by anyone ever. Screw plate into rear bumper. If you're super concerned about scratches, use some PPF and a spacer. Move on with your life.
You guys are crazy.
Golf R
Really? You must be kidding right? 3M Velcro adhesives are good for over 200°F...do you really think the licence plate area of the bumper is in danger of going over 200°F?? The bumper would melt or warp before the adhesive would say "I'm done".
FYI - Since Velcro is certified for use in aircraft interiors, it is quite capable of handling any temperature that the body of a car would be exposed to.
You guys are crazy....
Absolutely! Crazy enough to not drill unnecessary holes and add fasteners that can rust or corroded, or come loose over time...:cool:
Why are you so caught up in something being "certified" for use in aircraft interiors? Interior panels have been know to fall off in turbulence, and are subject to significantly less vibrations than a vehicle. I agree with you about heat likely not being an issue, but your bumper isn't going to melt at 200F.
Stainless steel fasteners through plastic will not corrode. Using a locking nut on the back side of your bumper will ensure that it doesn't "come loose" over time if you're really concerned. Adhesive is FAR more likely to fail over time than a mechanical fastener.
Screwed that thing in as soon as it arrived in the mail. Got rear ended, and did the same thing again on the new bumper. If does scuff the paint but it's never visible.
This is coming from someone that put a black sticker over the stupid rotating volume knob.
As others have said:
1. Volvo rear license plate bracket
2. Well Nuts
3. 10-32 stainless screws
You pick the size well nuts and screws. Here are examples. See post 33 below.
MEASURE 4 TIMES- then drill holes. Be sure you have proper spacing to center plate horizontally and vertically.
I used painter tape to cover bumper when drilling
https://www.amazon.com/MTC-VM680-30762264-License-Retainer/dp/B01CGNXP2I
https://www.homedepot.com/p/Everbilt-10-32-tpi-x-5-8-in-Brass-Expansion-Nut-814358/204276054
#33
I can't believe that Amazon had it at the house yesterday already. Installed it last night and it looks awesome. Thanks!
Woo! Great man.
2. Well Nuts
#33
thanks again. but im asking for the cap nuts that will actually screw onto the volvo bracket to secure the plate...im assuming your reply was in reference to my question. if not, i apologize.
2021 HiHy Platinum AWD
They are M6x1mm acorn nuts (I measured tested them at Home Depot when I bought the kit)
21 - 40 of 53 Posts
