Rear seat back removeal
375 Views 4 Replies 2 Participants Last post by  Jetta32696
Just as the topic says...I need to remove the rear seat back to make way for my leather.
Need removal instructions to get the upper part of the seat out. Can anyone help me???
Thanks again.
See less See more
2
1 - 5 of 5 Posts
Re: Rear seat back removeal (Jetta32696)
i can, if you look where the seat folds if you have 60/40 split there is a place where you have to unscrew like 4 or 6 bolts then.......take out the bottom half there are two bolts or 4 bolts depending on the outside....then you fold down the top half, and you have to take a screwdriver and push the locking mecanism that holds the two bottom corners in, and then they should just pop out.
Re: Rear seat back removeal (Euro Flavour)
I have the full bench now, but the 60/40 rear will be going in once they are removed...do you know how to get the full bench out?? Thanks
you have to undo the top so it folds down flat, look in the corners and there are two piviot points, you have to undue the locking mecanism that holds it in there, grab a screwdriver and there is a lil grove i guess you could say, stick it there, and push it back then pull the corner out, repeat for the other side
Fabulous!!! Thanks alot. On Saturday, I'll have leather seats finally after months, and months of searching!!! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
6
1 - 5 of 5 Posts
