Rear seat reading lights
647 Views 9 Replies 9 Participants Last post by  CHUBBY ASIAN
Just installed a set of these, but they are a bit diff. than what everyone else is putting on.
Let me know what you think.
And yes, they lit up when I open the door or trunk.
I also installed this one in the foot well, helps me out if I drop soemthing down there and can't find it. I was gonna paint it black later on so it matches.
The lights are from a 2001 Jetta that I found on the junk yard. rear lights are 3 way switch, wich means they can lit up when the door opens, or by manualy pressing the lite or you can turn them off completly. The little one in the foot well is also from the same Jetta and MK4's have them under theis flip down visor. So what you guys think? I like it, lits up like a Christmas tree.
See less See more
5
1 - 10 of 10 Posts
Re: Rear seat reading lights (NightRyder97)
Very one-off and functional! I like em!
Re: Rear seat reading lights (Y2KRICEBOY)
Wow, those are cool! http://****************.com/smile/emthup.gif
T.C.
See less See more
2
Re: Rear seat reading lights (collins_tc)
NICE !! one mans junk is another mans reading lights
See less See more
Re: Rear seat reading lights (phat-black-dub)
schwwwwwwwwwwweeeeeeeeeeeeeettttttttttttttttt!!!! http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif http://****************.com/smile/emthup.gif
See less See more
3
is there a how to guide type thing on doin this? im interested
See less See more
sweet how did you wire them in
Re: Rear seat reading lights (jayseal22)
wiring is easy, there are 3 wires coming out of the rear lights, and two out of the little ones on the bottom. I wired them up at the sunroof switch. If you pop it out there should be 4 wires coming into it. first one is ground I believe, then the two in the middle are positive, and the last one seems to be ground again but I didn't use it. Now the key is in the two middle ones that are positive. If you wanna connect just the little light with two wires, you connect it to these two wires. Why? Because once you open the door or trunk one of the wires becomes ground, opens the circuit and you have light. voila!!!
Same thing you do with the lights that have 3 wires, figure out which wire is ground and which is for door ajar lights, and which is for continous light. Use some wire, connectors and that wire loom or sumtin to protect them and there you go. You need to remove parts of the headliner to do this and it can time consuming. But the end result is very good.
See less See more
..What I want to know is when do I get my set of lights ?
After looking at your pictures, I can't wait !
See less See more
yummy mkiv reading lights http://****************.com/smile/emthup.gif
See less See more
1 - 10 of 10 Posts
