1 - 6 of 6 Posts
Tried some research but ain't really found what I want to know...
I'm rollin a 96 Golf 4cyl dropped on Bilstein SP and H&R Sport springs.. I have the OEM 17mm front sway bar. Just bought Front Upper and Lower OMP stress bar, waitin the upper rear stress bar and wanted to know: How do I know which diameter of rear sway to buy to fit with the combo I have right now ? 25mm ? 28mm?
all advices are welcomed
Re: Rear sway bar sizing questions (briang)
I've seen that there is no price difference anyway between 25 and 28...
so $ isn't an issue... need the most adapted part for my little ride
Modified by A3dOUde at 7:30 PM 7-2-2003
Re: Rear sway bar sizing questions (A3dOUde)
Go NS 28 you can always adj. it softer and it doesn;t seem you can go too stiff on our VW's
Re: Rear sway bar sizing questions (joeblow)
Go with the 28mm bar, its not as "extreme" as you may believe. The 25mm will have you wanting more more more.... I have the 28mm on my car and put it on the medium setting from day one. The car handlies just great and helps a ton when I auto-x. I've always been tempted to put it on the stiffest setting but have just been too lazy
Discussion Starter · #6 ·
Re: Rear sway bar sizing questions (Lexi)
ok thanx folks... keep you informed when everything will be all set
1 - 6 of 6 Posts
