Re: Rear WIPER HELP (remedyz53)
Quote, originally posted by remedyz53 » |
i have the plastic inside taken off and now im trying to get off the wiper it self, it says use the13mm socket to remove the bolt but on our cars its like connected to the wiper...its wierd? any help? |
The entire wiper arm is removable from the outside ot the vehicle. You have to remove the plastic cap the covers the pivot point. It just pops off by...
- gently pry up the plastic cap with a flat head screw driver, you are going to pry around the circumference until the cap is moved away from the glass
- now you can snap the cap off of the a rod that it is snapped to.
Now you can use the a deep 13mm socket or an open ended wrench to remove the single nut that ties the entire wiper arm to the back of the vehicle. After you remove this nut and the wiper arm, you will still have the pivot point with the spray nozzle still attached.
