1 - 1 of 1 Posts
While replacing the OBX washer and bolts with a better quality set, I couldn't help but notice that you cannot bolt down the output flanges to the diff, the threaded washers are missing.
I can install the OEM threaded washer but I am concerned because they will be between 2 moving gear and the washers are aluminum.
Any suggestions?
Your help is greatly appreciated.
This is a diff that came with the threaded washer installed
This is the aluminum threaded washer
This is where the washer could me installed but it will be between 2 hard steel gears.
1 - 1 of 1 Posts
