so i rebuilt the engine and i set the timing the way it should be,i put in the battery finished up all the wiring and turned it over a few times to prime the pump and then cranked it over a few times with no luck it fired once and that was it so i'm thinking maybe i over looked something any ideas guys?
i hooked up the plugs on top of the airbox, i also hooked up head sensor plugs, i hooked up o2 sensor i hooked up the tps/full throttle sensor/switch
umm battery and starter cables ground is good... and the distrubuter as well....maybe im missing something?
also the fuel pump primes as well
