Anyone else get a notice from Volkswagen of Amercia, inc. If so have you had it done yet? Below is a quote from there letter!
Problem Description: If the rear tire of the passenger side of the vehicle is severely under-inflated or has lost all air, and the vehicle is operated at highway speeds, the affected tire may quickly overheat leading to its disintegration after several miles of driving. We have found that fragments of a disintegrated tire rotating at high speed could damage the wheel well liner of the vehicle and other nearby components, as well as the nearby filler neck, which is an integral part of the fuel tank. Damage to the filler neck could cause a fuel leak with risk of fire from external ignition sources.
