quote:[HR][/HR]Are there any adjustments that can be made to the motors?[HR][/HR]
Not without tossing on a capacitor. What kind of adjustments did you have in mind?quote:[HR][/HR]Can the motors be replaced?[HR][/HR]
Yup. You could probably match it pretty well with a motor out of an Audi. Just a guess though.quote:[HR][/HR]Can I swap the passenger side motor to the driver's side frame?[HR][/HR]
The beauty of Recaro's...Infinite adjustability. You could save time and just swap the frame I bet.quote:[HR][/HR]Any other options to consider?[HR][/HR]
Did you install the original wiring harness from the donor car for the seats? It only takes a second to take out and put in. If you didn't get the harness, is your setup relayed?Double check your connections. You might want to verify that the driver's motor is getting enough juice. My passenger motor was like yours until I cleaned up the connections. It's better, but could be stronger still.
Which Recaro's did you get? Black vinyl with Grey centers, blue vinyl with diagonal color blocks or Blue/grey fabric?
