1 - 4 of 4 Posts
ive tried and enjoyed mtl in my A2 but i know some people use mt90...just wanting to hear from peope that have tried both
if your reading this, give it a bump cus i wana know
Re: redline MTL vs MT90 anyone tried both (pigbladder)
Quoted from this thread:
http://forums.vwvortex.com/zerothread?id=1344270
Quote, originally posted by PDXGTI8V »
I tried the MT 90, which is the 75-90 you're talking about and my shifting was quite sluggish. I switched to the redline MTL, which is a GL-4 fluid that vw recommends for our trannys.....it shifts so much better and smoother than the MT-90....use the MTL, you'll be happier with it
Apparently when referring strictly to VW's specs, the heavier MT-90 is closer to spec, but the MTL works better at cold temps... and seems to provide the high-end temperature protection as well. IIRC, the MT-90 is recommended for later model VW's (Mk3's?).
I use MTL and have been very pleased with the results. It makes shifting like butta.
1 - 4 of 4 Posts
