1 - 11 of 11 Posts
I don’t like the idea of using two head gaskets and I don’t have the money to four low-comp pistons, so I think I have to mill my cylinder head.
Does anybody know where Ill can cut out the 6cc I want to get rid of?
/Ted Duell
-Arthur Dent also drives a golf gti!
Re: Reducing comp on the 16v-head? (rocco2nr)
The advantage of milling the head is said to be better cooling and smaller knock tendencies.
But how much pressure could the pistons take after being dished?
"Access to a lathe" means?
Re: Reducing comp on the 16v-head? (ypzilon)
quote:[HR][/HR]Isn't it 10:1 pistons I've got now?[HR][/HR]​
I think psi meant 1.8L 8v 10:1 pistons. Is that right ChuckB ?
rocco2nr, could you give us the specs of your dished pistons?
quote:[HR][/HR]why not dish the pistons? [email protected] dished mine for 9.2:1 (PL pistons), i can tell you the specs if you have access to a lathe...[HR][/HR]​
i wouldn't mind knowing the specs, if you don't mind...
i have a lathe at home and a spare PL engine
-nigel.
Discussion Starter · #9 ·
rocco2nr:
What is your boost level with that mod on the pistons?
How long have they survived?
How much boost could the pistons take with that decreased strength?
[Modified by ypzilon, 7:46 AM 12-4-2001]
quote:[HR][/HR]I don’t like the idea of using two head gaskets and I don’t have the money to four low-comp pistons, so I think I have to mill my cylinder head.
/Ted Duell
-Arthur Dent also drives a golf gti![HR][/HR]​
You DONT want to mill your cylhead, that'll take away cc's and you want to add cc's to you chamber, otherwise you'll raise the compression ratio.
Paul
Discussion Starter · #11 ·
Re: Reducing comp on the 16v-head? (killa)
Paul:
Maybe a confusion of tongues, I want to remove ccs of aluminium from the head. The cylinder volume will be the same but the combustion camber will be bigger, and I'll get lower compression...
1 - 11 of 11 Posts
