Re: relationship of transmission mount to motor mount (JettJagwar)
Wow!
Sorry about the bad news.
I believe the VR6 engine is held in by three mounts. There is the front-center mount, passenger-side rear mount, and driver-side tranny mount. When they installed new bolts on your tranny mount, I assume they would have to remove the top bolts on all three mounts to free the engine from the frame. Then you would push the engine towards the rear just far enough to gain access to those three tranny mount bolts. This can be done with your trunk scissor jack (stated in the Bentley manual).
When I replaced my clutch, I over torqued one of those tranny bolts (the longest one) and had to order a replacement bolt. I used the scissor jack technique, and it worked great.
I'm thinking that they were the ones who probably messed with all of your engine mounts when replacing your broken bolts. You might want to check into what was required for them to replace your broken bolts (ie. did they touch your other engine mounts).
I'm still confused regarding an engine mount bolt breaking your block. How did they get inside the engine???
Did you notice any oil leaking from your block when you heard those noises?
My other question is warranty. Are you the original owner? How many miles do you have on your car?
Wow!
