1 - 20 of 73 Posts
Hello and welcome to chapter 2 of adventures in reliable transportation (see chapter 1 here). In this instalment I give you this fine example of a fully depreciated luxury sedan, this full size, this four door, this Audi A6.
Specs:
2005 Audi A6 3.2L FSI Quattro
Oyster Grey Metalic
Sport package
Cold weather package
Premium sound
Bi -xenon with AFS
113k miles
Check engine light: on.
First order of business was the headlights, these had some of the worst fogging I've ever seen.
IMG_20150713_091602 by Raven, on Flickr
It took about an hour per light, started with 800grit, then 1k, then 2k, then a plastic polish, and finished with a bit of wax.
IMG_20150711_172420035_HDR by Raven, on Flickr
It's not perfect but its a huge improvement and should get me by until I have a chance to shoot them with some clear coat.
IMG_20150712_202011492 by Raven, on Flickr
I'll update this thread as I fix the things that that have gone wrong with it (and what ever else self destructs along the way).
2016 A6, 2014 X3, 1967 Bus, 1963 356
How much did you pay? These kinds of threads are best supplemented with numbers so we can all go "wow, he has total comfort and luxury for the price of a TV!"
Discussion Starter #9
Have you scanned the car for codes yet?
Codes? yes, it has them.
Address 01: Engine (AUK) Labels: 06E-910-559-BKH.lbl
Part No SW: 4F2 910 559 B HW: 4F1 907 559 A
Component: 3.2l V6 FSI 0030
Revision: --H15--- Serial number:
Coding: 0000000000000000
Shop #: WSC 02116 444 64487
VCID: 2B5E81428AED4379EBD-807E
2 Faults Found:
012410 - Air Intake System
P307A - 009 - Flow too Low
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 254
Reset counter: 40
Mileage: 163288 km
Time Indication: 0
Date: 2014.01.17
Time: 14:51:07
Freeze Frame:
RPM: 704 /min
Mass Air / Rev.: 185.3 mg/str
Temperature: 66.0°C
Idle
Voltage: 13.46 V
Speed: 8.0 km/h
000104 - MAP/MAF <-> Throttle Position Correlation
P0068 - 007 - - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 5
Reset counter: 40
Mileage: 163288 km
Time Indication: 0
Date: 2014.01.17
Time: 14:51:07
Freeze Frame:
RPM: 704 /min
Temperature: 66.0°C
Idle
Voltage: 13.36 V
Bin. Bits: 00000010
Readiness: 0000 0000
Not a bad price. As for the plate filler, go with the simple one. Once you start doing RS grilles it's a slippery slope on performance looking mods on a non-performance oriented car and that's when it goes from classic to clapped out.
The tiptronics get sticky servo valves in the valve body, and the Torque Converter seals leak. You can keep it in manual mode to mask some of the issue.
Technically the gearboxes are fine. You can replace the valves alone, but it's difficult to figure out which one you need. And the TC fix is pricey. Will make you strongly consider a manuel swap.
1 - 20 of 73 Posts
