1 - 5 of 5 Posts
hello all.
I would like to find out how to program the remote on 2002 Passat B 5.5 to do the following.
1. Unlock all the doors when unlock is pressed on the remote.
2. Automatically unlock all doors when the key is removed from the ignition.
3. Lock all doors when travel above 10mph.
please post here is you know how to program them...
thanks
Re: remote programming? (eggyacid)
Are you asking if a 2002 remote can do these three on your 1999?
My 2003 B5.5 does these, except unlock when the key is removed but the front doors unlock when the handle is pulled and the rears on the second pull.
Isn't this the same on the 2004 Touareg? I'm guessing you like the features of the new ride.
I would think that it would be more than just the remote that would need to be programmed.
Modified by mmaxwell2112 at 5:57 AM 5-22-2004
My Jeep had a feature in which the doors would all lock when the car hit 15 mph. Can a 99 passat be programmed to do that and also to unlock the doors when the key is either turned to the off position or removed from the ignition?
1 - 5 of 5 Posts
